Buddypress integration & Rates
(@sjoerd-walburg)
[#12387]
Yesterday I bought the Buddypress addon for WPDisuz. However, the rating is not displayed properly in Activitystream ( https://www.intopic.nl/activity/) and it is also not displayed properly in the profile ( https://www.intopic.nl/leden/redactie/discussions/rates/). Who can help me with this?
Thank you in advance!
Hi @sjoerd-walburg,
Could you please provide a screenshot illustrating the issue? This will help us better understand and address the problem efficiently.
(@sjoerd-walburg)
The first thing is that the Buddypress integration options for profile only visible are for the Admin account. Not in the public for members?
Member:
Schermafbeelding 2024 01 14 om 08.02.05
Admin:
Schermafbeelding 2024 01 14 om 08.07.58
The second problem is that ratings not shown:
Schermafbeelding 2024 01 13 om 18.57.32
But in the reaction you could see it correct:
Schermafbeelding 2024 01 13 om 18.57.08
@sjoerd-walburg,
The addon adds only if the article is rated and/or the comment is voted.
» Settings ‹ wpDiscuz — WordPress — Mozilla Firefox
subscriber – wpDiscuz   Google Chrome
For privacy reasons, this feature is disabled by default. You can control it using the hooks provided below:
  • wpdiscuz_bpi_user_has_access_to_discussions_tab
  • wpdiscuz_bpi_user_has_access_to_comments_tab
  • wpdiscuz_bpi_user_has_access_to_reactions_tab
  • wpdiscuz_bpi_user_has_access_to_rates_tab
  • wpdiscuz_bpi_user_has_access_to_subscriptions_tab
  • wpdiscuz_bpi_user_has_access_to_votes_tab
  • wpdiscuz_bpi_user_has_access_to_follows_tab
  • wpdiscuz_bpi_user_has_access_to_followers_tab
This is an example:
add_filter('wpdiscuz_bpi_user_has_access_to_rates_tab', '__return_true');
The remaining tabs should be enabled using the same logic.
(@sjoerd-walburg)
Thank you very much. Where do I need to put that text? I am not a very good programmer?
And is this also the solution for not showing a rating on the right tab in profile?
@sjoerd-walburg,
Sure this doc should be helpful for you: https://www.wpbeginner.com/plugins/how-to-easily-add-custom-code-in-wordpress-without-breaking-your-site/
No the code is solution for your secon quetsion. Please read attentively my answer:
