[Solved] Points display issues
(@chris-r)
[#5321]
There are a few issues with the displaying of points.  They currently display like this: points:19000
I believe they should look like this: Points: 19,000
1. The P should be capitalized like it is in the wpForo myCRED addon.
2. There should be a space right after the colon and before the first digit. It's also like it is in wpForo myCRED addon.
3. There should be a use of a comma when thousandths are used.  This is also an issue is the wpFORO addon and should be fixed there as well.
You can see the attached screenshots for reference.
wpDiscuz example
wpDiscuz
wpForo example
wpforo
Thank you,
-Chris
Hi @chris-r,
Please leave the example URL to allow us to check it.
(@chris-r)
@elvina
Hi Elvina,
I just pm'ed you with the links.
Thank you,
-Chris
@chris-r,
Thank you.
Please navigate to the Dashboard > Comments > Settings > Styling admin page, put the following CSS code in the "Custom CSS code" textarea:
#wpcomm .wpdiscuz-mycred-points-wrap {
text-transform: none !important;
The issue will be fixed in the next version update.
In case if  you want to solve it as soon as possible please follow the steps below:
1. Find this line:
$afterLabelHtml .= '<div class="wpdiscuz-mycred-points-wrap">' . $pointsLable . ':' . $balance . '</div>';
2. Replace with the following one:
$afterLabelHtml .= '<div class="wpdiscuz-mycred-points-wrap">' . $pointsLable . ':' . '&nbsp' . $balance . '</div>';
Don't forget to delete all caches and press CTRL+F5(twice) on the frontend before checking.
We'll take it into consideration.
However the Points value comes from MyCred plugin, so it will be better if you contact MyCred plugin support and asked them this question.
(@chris-r)
@elvina
Hi Elvina,
Man! You're on top of this forum!  I really appreciate the help.
Posted by: @elvina
That worked like a charm!
Posted by: @elvina
1. Find this line:
Awesome!  I'm glad its being fixed in an update, I think I'll just wait for that.  I do appreciate you offering a quick fix in case I needed it right way.
Posted by: @elvina
Hmm. that's weird, the points are showing up with a comma in both my theme (Logged in menu) and the Ultimate Member profile.  The only places they aren't are wpForo and wpDiscuz.
I will try to reach out to the MyCred team though like you suggested and see what I can figure out.
Thanks again Elvina,
-Chris
(@chris-r)
Hi Elvina,
I explained the situation to the MyCred developers and heard back from them.  This is their response:
These are third party plugins they are not using the function which adds the comma in the points.
They can use the below example code in their plugins to make the points format as per the settings.
$point_balance = new myCRED_Point_Type();
$point_balance->format( 16040 );
https://codex.mycred.me/objects/mycred_point_type/
Hopefully this helps.
Thank you,
-Chris
@chris-r,
Thank you for sharing the information.
We'll take it into consideration and try to add in the next versions update.
(@chris-r)
@elvina
You're very welcome!
Thanks and take care,
-Chris
