[Solved] Change place badges
(@gaskt)
[#3861]
Good evening, I'm a programmer and I bought all the extensions of your plugin, I want to start by congratulating you for the great work.
I wanted to know how I can do to change the place badges on my site, and instead of appearing below the avatar, it should appear to the right side of the author's name.
Sem título
I can accomplish with css, but it does not look good, I wanted to know if I could change the emblem code of the functions.php in some way to put the badges there
Hi @gaskt,
You should customize the class.WpdiscuzWalker.php file as described in this doc:
https://wpdiscuz.com/docs/wpdiscuz-documentation/customization/custom-template-and-style/
In overridden files, you should change the position of the wpdiscuz_after_label hook, replace it beside the comment author avatar.
However, please note if you use the wpDiscuz Advanced Likers add-on please note this changes will replace the likers add-ons badges as well.
(@gaskt)
Thanks for responding so quickly.
I really had not thought of this possibility, I'll do it that way then.
I hope they continue the great work, soon I will be acquiring WpForo as well.
