WpForo profil integation ?
BillMoo
(@billmoo)
I use wpdiscuz and wpforo and thank you for these awesome plugins. I have a simple question about the integration « link to profil » when I clic on the avatar on the comment section. I saw the integration code about buddypress, mycred… but, what about the profil page of wpforo ? What is the code ?
Thanks for your help 😉
BillMoo
(@billmoo)
Ok, we had to click on the name, not on the avatar ... Oops
BillMoo
(@billmoo)
Currently, a new page opens with the profile. Is it possible that the profile page does not open on a new page? I prefer to stay on the same page.
Tanks for yout help.
Hi  BillMoo,
Please wait for the next (wpDiscuz plugin) update. We'll provide a hook and you'll be able to delete target="_blank" attribute.
BillMoo
(@billmoo)
Oh cool ! Thank you ! 😉
BillMoo
(@billmoo)
Hello ! I had deleted the target = "_ blank" in class.WpdiscuzWalker file and it worked perfectly ! But since the last update I think, the problem is still there. When editing the file, the new page appears when I click on the username. Please, what can I do ? Thank you.
Could you please explain the issue again. What do you mean saying this "When editing the file, the new page appears when I click on the username."? What is the problem?
BillMoo
(@billmoo)
Ok, sorry I'll try to explain myself better.
Problem => Currently a new page (the profil page) appears when we click on the username, this is the default setting of the plugin.
What I want => I would like to stay in the same window when I clic on the username.
A few weeks ago, in the file "class.WpdiscuzWalker" I deleted the lines "target =" _ blank "and the result was good, but today it does not work anymore and the default setting is back.
Hi @billmoo,
Please put the following code in your current active theme functions.php file:
add_filter('wpdiscuz_author_link_attributes', 'targetSelf');
if (!function_exists('targetSelf')) {
	function targetSelf($args) {
		if (isset($args['target'])) {
			unset($args['target']);
		return $args;
The following code removes target =_ blank attribute when you click on avatars of commentators:
add_filter('wpdiscuz_avatar_link_attributes', 'targetSelf');
		return $args;
BillMoo
(@billmoo)
Finally it's working ! Thanks a lot !
