wpDiscuz comment form is missing
(@stableton)
Topic starter   [#3760]
I'm having an issue with my site where I can see my WPdiscuz comments just fine, but the comment box where you type the comments has disappeared.
I've followed all the instructions here https://gvectors.com/forum/how-to-and-troubleshooting/resolved-wpdiscuz-comment-form-is-missing/ and it's still missing.
Screenshot 2019 04 05 at 17.43.54
If it helps I'm using the OnFleek Wordpress theme. What's weird is that the comment box field used to be there, but I recently did a clear out of old inactive plugins that I didn't use and since then it seems to have disappeared. Could that have caused it? If so I can't remember which plugins I removed as it was a while ago.
I've also deactivated and removed WPDiscuz and then reinstalled the plugin. That didn't work.
Hi @stableton,
Please leave some example URL to allow us to check it.
No. I don't think that the problem is caused because of deleting the plugins. Probably you've updated some plugins or active theme and it caused the issue.
(@stableton)
Hi @Astghik,
Here is a link https://www.stablevehiclecontracts.co.uk/blog/car-tyre-pressure-guide/
As you'll see there is a comment from when someone left one when our comment box was working, but now it has disappeared. I don't think it's any CSS rules either, I've had a look. We are using display: none on our old comment box as this was part of the Wordpress theme.
@stableton,
Check the WordPress post "Allow Comments" option. This option is located on all posts/pages edit page.
1) Make sure the "Discussions" admin-box is allowed using "Screen Options" in "Edit Post" admin page:
wpDiscuz-form-missing
2) Find the "Discussions" admin-box below and make sure "Allow Comments" option is turned on.
wpDiscuz-form-missing-2
(@stableton)
Hi @Astghik,
This has always been toggled on.
Screenshot 2019 04 08 at 14.35.08
@stableton,
Please check out the points mentioned here, and leave some feedback for each one
https://gvectors.com/forum/how-to-and-troubleshooting/resolved-wpdiscuz-comment-form-is-missing/#post-349
Also please leave the screenshots of the Forum Settings page.
Default form edit screen
