[Solved] Users can't post
(@le-tyran)
Topic starter   [#1762]
First, here is my website. (Which currently runs on Wordpress 4.9)
I just installed this plugin and since I could post with my admin account I thought it worked like a charm, but then I tried to post with a normal user account and I get this error :
SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
I tried to disable other plugins but it doesn't seem to change anything.
(@le-tyran)
Okay, it seems that this :
function restrict_access_admin(){
if ( current_user_can('subscriber') ) {
wp_redirect( home_url() );
exit();
In my function.php file was the culprit.
Everything works fine since I removed it : problem solved.
Tom reacted
 Stef
(@stef)
I think this error can be caused by a lot of things. In my case I installed a plugin called "The GDPR framework" by codelight and that one conflicted with wpdiscuz. I deactivated that one and everything was ok again.
