[Solved] Inverse drop animation for comment form after Submit
(@angelochiacchio)
Topic starter   [#5643]
Is there a way to close back the form to show only the first textarea after the user has submitted? Possibly with the same animation?
Right now I forced a display:none of .wc-form-footer on submit using jquery.
The goal is to show the user a feedback of his comment being posted.
Hi @angelochiacchio,
Please follow the steps below:
1. Put the following js code in the js files of the active theme:
wpdiscuzAjaxObj.wpdiscuzSlideUp = function () {
var parent = jQuery('.wc-main-form-wrapper');
jQuery('.commentTextMaxLength', parent).hide();
jQuery('.wc-form-footer', parent).slideUp(wpdiscuzAjaxObj.wpdiscuz_options.enableDropAnimation ? 500 : 0);
jQuery('.wc_comment', parent).focusout();
Helpful article: https://www.collectiveray.com/add-javascript-to-wordpress
2. The PHP code below should be put in the active theme's functions.php file:
add_filter("wpdiscuz_comment_post", function ($r){
$r["callbackFunctions"][] = "wpdiscuzSlideUp";
return $r;
(@angelochiacchio)
Thank you,
it doesn't work. Is the procedure the same while using a child theme?
(@angelochiacchio)
Actually the function is called but not recognized
Screenshot 2020 04 07 at 14.29.13
@angelochiacchio,
Please try to add the js code in the wpDiscuz plugin js codes. The wpdiscuz.js file is located in the /wp-content/plugins/wpdiscuz/assets/js/ folder.
Don't forget to remove it from the previous place you've added.
(@angelochiacchio)
I works now! Thanks a lot!
(@angelochiacchio)
However in doesn't seem to be working on mobile, which is more important. Any idea why?
(@angelochiacchio)
You can test it at http://ideasfortomorrow.me/
@angelochiacchio,
Probably this is just a cache issue. Please try on incognito mode. Because mobile browsers have a hard cache, you'll not be able to see the change immediately.
(@angelochiacchio)
Indeed. It is working fine now. Thank you!
@angelochiacchio,
In case you want to say thank you !)
We'd really appreciate and be thankful if you leave a good review on plugin page. This is the best way to say thank you to this project and support team.
