Incompatibility with NinjaForms
(@hercules227)
Topic starter   [#818]
is there a known incompatibility with ninjaforms?
I am using WordPress 4.6 (due to momentary high traffic on my site I will upgrade to 4.7 later),
Comments - wpDiscuz version 4.0.2, and Ninjaforms 3.0.20.
Recently the following error message started appearing at the top of my WP Dashboard: (see attachment)
Screen print wpDiscuz
It's in Dutch as my WP site is in Dutch. Translation: "Reaction form not found. Navigate to forms management page to create it".
I assume(d) this was a NinjaForms error message so I contacted Ninja support. They logged onto my WP dashboard and found that Comments - wpDiscuz was causing it. Disabling it removed the error message.
So I have 2 questions:
- is this a known incompatibility between Comments - wpDiscuz plugin and Ninjaforms plugin?
- is there any harm in leaving it as it is as far as you know?
For now, nothing seems broken on the site but I'd rather not have that error message stick out every time I visit the dashboard.
Thanks in advance
Patrick
This is not NinjaForms error. This is wpDiscuz notification. wpDiscuz 4 comes with Custom Comment Form API. It seems the Default Form has not been created on update process. Please navigate to Dashboard > Comments > Forms admin page, and make sure there is a Default Form. If there isn't, please click on [Add new] button and create at least one comment form. Then delete all caches.
hercules227 reacted
(@hercules227)
Wow, thank you, I didn't know. My comment form did look weird after upgrade to 4. But now it is fixed again. Thanks a million!
