Enabling guests to submit a question
(@manunika)
Topic starter   [#455]
Hi, I've just insallted the plugin, but I noticed that one needs to be logged in in order to submit a comment or reply...do you know if it's possible to enable normal users(guests) to post an answer without the login process?
Moreover If the login is required guests are redirected to the wp admin login which is not ideal...how can I change the url?
Looking forward to your reply
regards
Hi manunika,
Just uncheck/disable this option:
wpDiscuz no guest comment
(@manunika)
Opss I didn' think about that...thanks a lot for the prompt answer!!
