[Solved] Custom Display Ratings
2 Reactions
(@carmechanic)
Topic starter   [#5252]
It is possible to hide star rating "text" and leave only stars ? Custom CSS ?
Topic Tags
Hi @carmechanic,
You should use the CSS code below:
1. The following code hides the text in the commenting area
.wpd-field-rating .wpd-field-group-title {
    display: none;
2. The following code hides the text in the comment area
.wpd-cf-rating .wpd-cf-label {
display: none;
The CSS code should be added in the "Custom CSS Code" textarea, located in the Dashboard > Comments > Settings > Styling admin page.
Please don't forget to delete all caches before checking.
(@carmechanic)
Unfortunately it doesn`t work for me. After paste CSS code in Comments > Settings > Styling admin page., still have "Rate (3/2) test over the stars average 🙁
@carmechanic,
Please leave some example URL and show on the screenshot what exactly you'd like to hide. I'll try to provide a CSS solution for you.
(@carmechanic)
delete
Sorry for my long time reply. This text of "Rate 3/2" is above average star rating as I show on screenshot. I want to hide this text and if possible,  move this stars icons in to the top-middle comment box ( second screen )
moved
Hi @carmechanic,
Please remove the CSS code provided above, and use the following one:
.wpdiscuz-stars-label {
display: none;
.wpdiscuz-stars-wrapper {
margin-left: 110px;
The red marked value can be changed as you need.
Please don't forget to delete all caches and press CTRL+F5(twice) on the frontend before checking.
carmechanic reacted
(@carmechanic)
Problem solved. Thank you for great support !!!
Astghik reacted
@carmechanic
We'd really appreciate and be thankful if you leave a good review on plugin page. This is the best way to say thank you to this project and support team.
(@carmechanic)
I will 🙂
