Hi we are using Wp-discuz (latest version) with The7 theme
The comment form isn't working. Won't let us post, reply, order posts.
see link: http://bit.ly/2r7b8Br
You have JS errors on your website, they affect wpDiscuz. This problem comes from your plugins or current active theme. please leave some URL to allow us check website errors or deactivate all plugins, delete cache and test it again.
Hi Tom,
Thanks for responding. What URL do you need?
Takes you to a page on our website.
First please make sure the "Enable wpDiscuz on home page" option is enabled:
Then start fixing your website JS error. You got lots of JS errors which affects other plugins and wpDiscuz as well. The main error generator is the "mts-wp-notification-bar" plugin you're currently use. Try to deactivate it and delete cache.
Hi Tom,
We examined the error. Seems to be due to our CDN. We excluded the files from the CDN and wp-discuz seems to be working again.
Thank you for letting us know.
