[Solved] Changing hyperlink color
(@ofirbeigel)
Topic starter   [#1586]
What do I need to add in the custom css in order to change the color of the hyperlink inside a comment to blue? Currently it's showing as green.
Put this CSS code in Dashboard > Comments > Settings > Styling > Custom CSS Code Textarea. Save it, delete all caches and do Ctrl+F5 on front-end:
#wpcomm a:visited {
    color: #0073aa;
#wpcomm a {
  color: #00a0d2;
#wpcomm .wc-comment-text > p > a {
   color: #00a0d2;
(@henrimatthijssen)
This is not working for me in the latest wpDiscuz 5.0.2. I thus have the same question again (preferable with using the 'wpdiscuz.css' file in the Themes directory):
How can I change the color of a hyperlinks in the comments? In my case they have the same color as the other comment-text thus you cannot see it.
See also below where word 'forum' is a hyperlink:
hyperlink
Please leave website URL.
Also please don't set label background white. It should be transparent.
(@henrimatthijssen)
Posted by: Tom
The URL of the screenshot is: https://eye-vision.homeip.net/plex-en-hdhomerun-met-ziggo-smartcard/#comment-68123
How can I set label background to transparent with custom css (wpdiscuz.css in Themes directory)
Do you use the wpDiscuz Dark Style? If you don't please navigate to Dashboard > Comments > Settings > Styling admin page and change the Style to Dark.
wpDiscuz dark style
screenshot 2
(@henrimatthijssen)
This does not solve the problem. Still the hyperlink is shown in the same color.
Further I actually do not want to change the wpDiscuz Style to Dark as I made some changes in the copy of the wpdiscuz.css file in Themes directory for the default style.
This means I still have the same question: "Which setting to change/adapt in the wpdiscuz.css file so the hyperlink is shown in a different color." (for the default style).
Thank you very much in advance for your assistance.
Please try to use following CSS code:
color: #00f;
(@henrimatthijssen)
I tried this but it does not solve the issue (I made sure that all caches were deleted and explicitly refreshed the page with CTRL-F5).
(@henrimatthijssen)
Found the solution! You need to add '!important' behind it:
color: #00f!important;
