Search
Close
AI Search
Classic Search
 Search Phrase:
 Search Type:
Advanced search options
 Search in Forums:
 Search in date period:
 Sort Search Results by:
function call to as...
function call to assign wpForo user role?
(@dlinstedt)
  [#5785]
Hi team,
As always, stellar product, fast, efficient and reliable!  Love it!
I am wondering if there is an acceptable function call in wpForo, to assign a user a new primary wpForo based role?
I am working with wpFusion, and when a tag changes I need to "change the wpForo role".
I don't want to sync with wordpress roles, for many reasons - so I am looking for an available function call in wpForo to get this done.  It would be nice if there were an API callback for this.  I am sure I am not the only one that could use this functionality (nearly everyone using wooCommerce would need this too I think).
Thank you kindly,
Dan
(@dlinstedt)
Found the code in wpf-hooks.php line 2521  wpforo_update_usergroup_on_role_change
however, cannot call that function UNLESS the sync flag is turned on.
I guess, what I am looking for is an additional optional parameter on the end of the call:
$ignore_sync_flag = 0  (default)
pass in a zero, and it means "look at the sync flag feature setting"
pass in a one, and it means: "set the role regardless of the sync flag feature"
I think, that would make it much more usable, then I could turn off the forced sync feature, and call this function to change a users' wpForo user group.
Thoughts?  (i've pasted the updated code below that would make this work the way I describe)
function wpforo_update_usergroup_on_role_change( $userid, $new_role, $old_roles = array() ,$ignore_sync_flag=0){
if( wpforo_feature('role-synch') || $ignore_sync_flag==1 ) {
$user_ug_id = WPF()->member->get_usergroup( $userid );
$role_ug_ids = WPF()->usergroup->get_usergroups_by_role( $new_role );
if( !empty($role_ug_ids) && is_array($role_ug_ids) ){
if( count($role_ug_ids) > 1 ){
$prime_ugid = array_shift($role_ug_ids);
if( !in_array($user_ug_id, $role_ug_ids) ){
WPF()->member->set_usergroup( $userid, $prime_ugid );
WPF()->member->set_usergroups_secondary( $userid, $role_ug_ids );
else{
$groupid = current($role_ug_ids);
if( $groupid != $user_ug_id ){
WPF()->member->set_usergroup( $userid, $groupid );
