Dear Mr.Tom,
Thank you for your help in advance.
I have a suggestion regarding WPdiscuz and WPforo plugins.
The most popular community, you know, is reddit.com
Comparing to this forum templates, reddit is author-centric.
The author's content is main and it consists of replies with small box like blog posts.
This forum template is popular in community like slickdeals, reddit, hotukdeals etc.
However, for WPforo, each replies has same room with topic author.
It's classic style forum, and It is suitable for the Q&A forums. However, it is not compatible with the post comment, WPdiscuz.
Therefore, for better community, it would be great if WPforo and WPdiscuz are collaborated together. Topic=(Frontend post writing + WPdiscuz reply) and then put together like WPforo forum style.
It's a so-called WPcommunity.
WPdiscuz=comment plugin.
WPforo=classic forum plugin
WPdiscuz+WPforo=communiy plugin like reddit style.
By combining the two, we can also share the addons and become a solo community plugin among word press. I'm looking forward to it 🙂
Thank you.
Best regards,
Heathera
Hi @hiyooo
Thank you for the suggestion.
I'm sorry but it's not possible to collaborate wpDiscuz with wpForo. wpForo Topics are not WordPress post types. wpDiscuz only works with WordPress post types.
This can be done through new Forum or Comment layout. We'll release new layouts soon. This one will be also taken under consideration.
Hi @tomson
Thank you for your reply.
I see. I hope you to take under consideration for sure.
I'm looking forward to it.
Thank you.
