Please My comment form is showing big avatar
(@steve4lyf)
Topic starter   [#3075]
I dont really understand what is going on. its showing big avatar on the comment form which is different from what i saw in the demo and other exampls. pls check the attached files
screenshot 20181024 114433
screenshot 20181024 114359
Topic Tags
(@steve4lyf)
here is a link sample:
https://www.sirstevemedia.com/news/sports/goals/video-manchester-united-0-1-juventus-champions-league-highlights-2018-19/
pls scroll to the bottom
Hi @steve4lyf,
Please reset all minified, optimized cache files. Delete all caches, purge CDN and press Ctrl+F5 on front-end.
(@steve4lyf)
I have done that. I use only wp super cache. i have cleared cache and done other stuffs, but still the same. @Astghik
@steve4lyf,
As far as I see the issue is already solved. Could you please check it using another browser?
comment
(@steve4lyf)
It appears only for logged in users, not guest.
i have tried it on several browsers.
ok @steve4lyf,
Please try to use the CSS code mentioned in this post.
https://gvectors.com/forum/how-to-and-troubleshooting/gravatar-is-so-bigggggg/#post-10562
Don't forget to delete all caches, before checking
If it doesn't help register the new user and send login details to info[at]gvectors.com email address. We'll check and provide CSS solution for you.
(@steve4lyf)
Thanks very much, its fixed .
