HOW TO DO THAT PLEASE
(@kezeo)
Trusted Member
[#11129]
hello for specific reason i would lile people need to purchase a membership to submit a post in a specific forum (everybody can read, but submiting a post require a membership
is it possible please ?
thank you
Kyle
 Kyle
(@kylew)
Prominent Member
Hi @kezeo,
That option is under consideration: Option to see the topics but CANNOT post a new reply
(@kezeo)
Trusted Member
@kylew,
thank you , maybe do that based on membership?
(@kezeo)
Trusted Member
BUT to be able submit A TOPIC only when we have a membership is ti possible please ?
Kyle
 Kyle
(@kylew)
Prominent Member
@kezeo,
Have you tested the options and the functionality of the Plugin?
(@kezeo)
Trusted Member
@kylew yes i tried i can restrict READ a forum BUT  i can NOT restrict to be able to submit a topic in a specific forum by a membership.
@kezeo,
wpForo WooCommerce Membership Integration addon cannot help you in this issue. This addon is designed to restrict access to some content, it's not designed to restrict actions. This is a content access restriction plugin, so this addon will never provide such function. If you want to add such feature, you should ask for custom development or try to do it with wpForo core features using wpForo Usergroups + Forum Accesses + WordPress User Role + Membership User Role Changing path.
For example, your Membership plugin should change users' User Role to a custom User Role which is capable to post a topic. We can call it "Topic Poster UR" user role. This User Role should be synched with a custom wpForo Usergroup in wpForo > Usergroups admin page. The usergroup name can be "Topic Poster UG". Then you should grant "Standard Access" to this usergroup to the forum where the user should be able to post a topic. Edit that forum and set "Standard Access" to "Topic Poster UG" usergroup. Other usergroups should be atatched to "Read Only" access. Here are more description: https://wpforo.com/community/wpforo-integration/ultimate-membership-pro-integration/#post-21911
The "Standard Access" should have "Can create topic" permission enabled.
(@kezeo)
Trusted Member
@tomson thank you very much, please do you know a Membership based on User Role  which Changing path ? i do not want to use ULTIMATE MEMBER
Thank you
@kezeo,
UM was not mentioned in the topic, it was Ultimate Membership Pro paid plugin from codecanyon. But nobody knows if this plugin is based on user roles. I have no Idea either, but I think most membership plugins are based on user roles. You can find one in wpForo community under paid membership tag: https://wpforo.com/community/?wpfs=paid+membership&wpfin=tag
BTW, I think it's better to create a custom addon which will add such feature to your existing plugins rather than install a new Membership plugin.
