Where do I set up myCred for wpforo?
(@dazhi-zhang)
[#12023]
I bought and installed the myCRED integration plugin.  However, I cannot find the addon configuration like the PM and Embeds addons.  It does say myCRED integration plugin is installed.  I just don't see anywhere I can turn it on for wpforo.
Is there any kind of documentation on how to enabled and set it up?
I tried to manually assign points to my users in the myCRED config panel but they don't show up anywhere in wpforo.
Please help.  Thanks.]
(@tiengduc-org)
Trusted Member
Posted by: @dazhi-zhang
You should come to the myCRED sections, click on the section Point, then choose Hooks. You will find myCRED wpForo hook there.
