[Solved] Possible to remove "Points:" from showing up for excluded roles?
(@chris-r)
I have the myCRED plugin installed to wpForo.  I have excluded a few roles from participating with the points system through myCRED.   The problem I'm having is, the phrase "Points:" is still showing up below those roles on the forum.  Can this be removed now or the ability to remove it be added in a future update?
Selection 001
Thank you,
-Chris
Hi Chris,
I'll ask the developers and let you know asap.
@chris-r,
please let us know are you using the latest version of the wpForo myCRED Integration addon (v. 1.0.9)?
(@chris-r)
Yes I am using the latest version of the the wpForo myCRED Integration addon.
-Chris
@chris-r,
This issue will be fixed in the next update. If you need to solve it asap, please follow the steps below:
1. Open the /wp-content/plugins/wpforo-mycred/wpforo-mc.php file
2. Find the displayPoints($member) function
3. Replace the whole function with the following one:
public function displayPoints($member) {
if ($member['ID']) {
$userID = $member['ID'];
if (function_exists('mycred_get_users_balance')) { //User Points
$balance = mycred_get_users_balance($userID, $this->core->cred_id);
if ($balance) {
$myCred = mycred_core();
$pointsLable = $myCred->point_types[$this->core->cred_id];
echo '<div class="wpforo-mycred-points-wrap">' . $pointsLable . ': ' . $balance . '</div>';
change the code
Warning: Making changes to active plugins is not recommended.
(@chris-r)
Awesome! Thank you so much for being so quick with this issue.
Thanks again and take care.
-Chris
