Search
Close
AI Search
Classic Search
 Search Phrase:
 Search Type:
Advanced search options
 Search in Forums:
 Search in date period:
 Sort Search Results by:
[Solved] Only give points in selected forums
(@langel87)
[#7271]
Hi again!
I'm following the answer they gave me on the pre-order page of the plugin, which said this:
You can use the hook-code proviede below:
add_filter(“mycred_add”, function ($execute, $data) {
if (($ref = wpfval($data, ‘ref’)) && ($forumid = intval(wpfval(WPF()->current_object, ‘forumid’))) && $ref === ‘wpforo_add_post’ && in_array($forumid, array(1, 2, 3))) {
$execute = false;
return $execute;
}, 10, 2);
Just change the value of the boldly marked part. Replace those with the Forum IDs there you don’t need to add the points.
My question is, where is this code added? Since I put it in the functions of my theme, adding the ID of the forums in which I do not want give points, but it does not work.
Thanks!
@langel87,
We've checked the code one more time it works fine. Please make sure you've inserted the correct code in the correct section. Please leave screenshots or video with the changes you've made.
(@langel87)
@astghik Could you tell me where to add the code, in what file?
Thanks!
(@langel87)
I have found the problem, the single and double quotes were backwards, here is the code:
add_filter("mycred_add", function ($execute, $data) {
if (($ref = wpfval($data, 'ref')) && ($forumid = intval(wpfval(WPF()->current_object, 'forumid'))) && $ref === 'wpforo_add_post' && in_array($forumid, array(1,2,3))) {
$execute = false;
return $execute;
}, 10, 2);
@langel87,
So may I mark this topic as solved?
(@langel87)
@astghik Sure! Thanks!
