myCRED integration
(@andres-moreta)
[#6045]
What if installed the add one first and the mycred plug in ? Does the orden change the result? Anyway can I delete the wpforum mycred and installed againg with the same key in the same website ?just brought simple licence
@andres-moreta,
yes, you can, the result does not change.
Posted by: @andres-moreta
yes, you can.
