Integration Confirmation
(@questiontravel)
[#12654]
Hi there,
I am looking for some answers about the functionality of myCRED in combination with WPForo with this add on. I tried contact myCRED but was told they have no ability to provide answers as it is a 3rd party plugin.
Hoping someone can answer a few questions for me:
1. How does this work with WPForo's built in reputaiton/point system? Does it override it, or integrate with it?
2. Is there a way to add points manually to a user? Not just by actions on the forum?
3. If I use this add on and also the myCRED Discuz add on - do the points all combine into one user account form both blogs & forum posts?
4. Can a specific amount of points be set for having an answer (in WP FORO Q/A forums) marked as the correct one?
Thank you kindly.
Posted by: @questiontravel
It doesn't overwirite the wpForo reputation system. You'll have both reputaiton systems.
You can edit the user profile and add the point in the according section.
he wpForo myCRED Integration and wpDiscuz myCRED Integration addons are different. With the wpDiscuz myCRED Integration, points are displayed in the comment author's section within the comment list.
The addon allows you to Awarded Points for answer.
