Align custom emoticons
(@wafadul)
[#5765]
How can i align my custom emoticons to the text in the post?
align
Hi @wafadul,
Please leave some example URL to allow us to check and provide some solution for you.
(@wafadul)
link
(@wafadul)
what does it take to get support around here? i see support staff answering questions posted earlier than mine. i hope you improve your system to ensure that the oldest post gets answered first.
i have been waiting for 5 days while some get answered just hours after posting.
it's just ironic that support is faster in the main forum which is actually FREE.
@wafadul,
Simply we've let the developers know about the problem you've faced. Please note not all support questions can be answered without contacting the developers.
Please wait a bit. I'll ask the developers If they can provide a simple solution.
@wafadul,
Currently, I see another issue.
icon issue
To solve it, use the CSS code:
.fa-window-close:before {
content: "\f410" !important;
The CSS codes should be added in the "Custom CSS code" textarea, located in the Dashboard > Forums > Settings > Style Tab.
 Please don't forget to delete all caches and press Ctrl+F5 (twice) on the frontend before checking to reload the updated CSS file.
@wafadul,
Try this CSS code. The main issue should be solved.
#wpforo-wrap .wpforo-post .wpforo-post-content img.wpf-smile, #wpforo-wrap .wpforo-post .wpforo-post-content img.wpfem{
vertical-align: middle;
(@wafadul)
okay, thanks.
i have a follow up question. the custom emoticons don't show up in the buddypress activity stream (please see attached file) - only the codes appear.
would it be possible to just hide it?
emoji
@wafadul,
I've checked the HTML code and there are no tags around the part, so it cannot be hidden anyway.
HTML
(@wafadul)
so there's no way to hide the smiley code in the stream? or show it as a smiley?
@wafadul,
I'm really sorry, but no. I've already explained why. However, I've already snd this link to the addon developers, They'll check and provide some workaround if it's possible.
(@wafadul)
okay, thanks so much!
@wafadul,
Please let us know the version of the wpForo plugin and the wpForo Emoticons addon you're using.
(@wafadul)
hi! was able to fix the issue by installing the the wp-Monalisa plugin.
btw, using the latest version of both your plugins.
