Can attach picture, but insert doesn't work
(@bernd-engel)
[#4650]
just installed your plugin on https://madtrash.com/community/ and it doesn't seem to work. I can attach 1 or more images. After uploading them I don't see the generated thumbnail, I see just the title. After I have selected the images with the checkboxes and press insert I'll get the error message, that I have to select the images by using the checkboxes. Ive checked the respective upload directory and no image files are there. I thought it was a problem with the chmod option, but changing this doesn't improve anything.
The console of Chrome inspection tool doesn't return any errors. Only if I try to delete the (obvisiously not) uploaded picture.
2019 10 22 21 17 23 Window
2019 10 22 21 18 58 Window
Can you please help.
Thanks, Bernd
(@bernd-engel)
I tried to deactivate and activate each plugin one by one ->> no success
I changed to different themes ->> no success
For this reason the reason can't be the theme or any of my installed plugins
@bernd-engel,
Please register some new testing user and send the login details to info[at]gvectors.com email address to allow us to check the issue.
Please make sure that the user can attach files.
(@bernd-engel)
@elvina
Thanks a lot, I have sent you the test user data a few minutes ago.
@bernd-engel
Please navigate to Dashboard > Forums > Dashboard admin page, make sure either the GD and Image Functions or the PHP imagick extension is available.
Then check your database table and make sure the table called wp_wpforo_attachments is created. If you don't find the table, please deactivate the add-on and activate it again.
wp_ is just a prefix, it can differ in your case.
Also, please check the Numeric value of the folder and make sure it is set 755.
More info here:
https://www.siteground.com/tutorials/ftp/change-permissions/
(@bernd-engel)
The attachment table was missing in the database. Added it manually and now it works fine...very cool, thank you!
I guess I know the reason why the attachments table was not created. When I've installed the wpForo main plugin, I faced some errors installing all tables in my database. The reason was my DB didn't recognize the default character set. I've changed the SQL code accordingly from 'utf8_general_ci' to just 'utf8' and created all tables manually in cpanel. After that the main plugin worked perfectly.
I'm sure the attachment plugin caused the same problem, while trying to create the attachment table. The install process of the advanced attachment plugin doesn't show any DB errors, so I got no idea.
