[Solved] Advanced Attachemnt not working
 Paul
(@paulgagu)
[#4055]
Hi there,
We have AA addon working for a year, our license expired so we renew the license and now is not working when you click to attach a file the popup for attachments appear you can attach files and upload them but when you click INSERT INTO POST nothing happens.
If I deactivate the plugin add-on user can upload/attach files to their topics (without the fancy GUI).
We're sure we:
1. Have Users Synchronized
2. Have users with CAN VIEW and CAN UPLOAD options
3. New users have 0 "zero" in limit pots.
We also download the last version and installed it. Clear all caches, synchronize.
Any ideas?
Thank you for help
Hi @paulgagu,
Please register some new user and send the login details with your forum URL to info[at]gvectors.com email address to allow us to check it.
 Paul
(@paulgagu)
Hi there,
We found the problem, wasn't a plugin problem.
The theme loads a JQuery instance in addition to the WP Jquery call.
We remove the call in the theme and the plugin works perfectly, sorry and thank you for your reply.
Thank you for letting us know Paul.
Glad to hear that the issue is solved.
