[Solved] Problems with WP FORUM 2.0.2 updates
(@miguel-torres)
[#10027]
I have some problems with the ADDONS. You can successfully update to WP FORUM version 2.0.2 and also update the complementary plugins.
Captura de pantalla 2022 08 04 a la(s) 05.05.55
In the blog (frontent) the complements work well.
Captura de pantalla 2022 08 04 a la(s) 05.09.06
but in the administrative area it sends me an error.
Captura de pantalla 2022 08 04 a la(s) 05.08.49
Captura de pantalla 2022 08 04 a la(s) 05.08.36
This happens to me with plugins:
  • Admanager
  • Advanced Attachments
  • Topic Custom Fields
The error only comes out when I want to go to the plugin settings, on the blog they work great.
Kyle
 Kyle
(@kylew)
Prominent Member
@miguel-torres,
have you updated those plugins that you mentioned to 3.0.1 version?
As those issues would be fixed after the update.
(@miguel-torres)
Thank you very much, the problem is solved.
st7878
(@st7878)
Should the old plugin settings be preserved? I updated and lost all settings. Reconfigure or did I update incorrectly?
st7878
(@st7878)
Understood. Everything has been preserved.
