Displaying ads only once after first topic post
 Liam
(@liamoc11)
[#6667]
Hi
I want to display an ad one time on the page, directly underneath the first topic post on the page. My pages are set to display 10 posts. If i set the frequency to 1, the ad appears under every post. If I set it to 2, it displays under every second post, and so on. Is there a way to target just between first and second post?
thanks!
Hi @liamoc11,
Use the CSS code below:
.wpfp-first ~ .wpforo-ad ~ .wpforo-ad{
display: none !important;
The CSS codes should be added in the "Custom CSS code" textarea, located in the Dashboard > Forums > Settings > Styles Tab.
Please don't forget to delete all caches and press Ctrl+F5 (twice) on the frontend before checking to reload the updated CSS file.
 Liam
(@liamoc11)
Thank @astghik
I did try this, but unfortunately it did not work. Maybe because I have other CSS already in that styles tab?
@liamoc11,
Please leave some example URL to allow us to check the issue.
Make sure the value if the  "Post List - Banner displaying frequency" option is set 1. We've just checked the code it works fine.
