Phrases in BuddyPress Integration addon
(@wp-user)
[#7673]
Hello gVectors Team,
I've purchased the BuddyPress Integration Addon and look forward to testing it out. One question I have is about changing some of the phrases. For example in the Notifications Settings page, it has:
If I want to change these phrases, should these be changed using a translation plugin (eg. Loco Translate) or is there a phrases section in the Addon that I've missed?
Thanks.
Hi @wp-user,
All phrases are available for change in the addon setting page, Please navigate to Dashboard > wpDiscuz > Settings > BuddyPress Integration Tab and change the phrases you want:
wpDiscuz BuddyPress Integration Settings Profile Tabs
(@wp-user)
@tomson Thanks for the reply. I see there are some phrases that can be changed there, but I was thinking more about phrases like this:
How can I change "Someone votes my comment" to "Someone votes on my comment".
Or change "Someone follows me" to "Someone is following me."
These are just examples, but any idea how I can change these phrases?
@wp-user,
There are no notification phrases, these are just option labels. If you want to change the option labels you should use Loco Translate plugin.
