Print Button not showing
(@clintonlee83)
The print button isn't showing. it's enabled. I've deactivated all the plugins and it's still not showing. The product meta data is displaying fine, I've tried the css: .woocommerce-page .product_meta{ display:block!important; } and it's not working.   Here's a product page: http://104.152.168.27/~signacom/product/crucial-4gb-1-x-4-gb-ddr3-notebook-memory/ Any ideas what's going on?
Please make sure those settings are turned on:
WooPP Settings
If all is correct, please send admin login details to support[at]gvectors.com email address. We'll check and find the issue.
(@clintonlee83)
The saving buttons work but the print button does not
I've emailed you sign in details.
Problem is fixed. The "Appearance mode of print button and string" option was set "Single". Please keep it set as "With saving buttons or strings". The Single value is only for template tags and custom functions.
