Custom Fields in Product Description
(@tiabradford)
I have been using PODS to create simple custom fields for my Woocommerce Store.
The fields show up under Product Description.
As seen here:
http://industrial.howitworks.com/product/giddings-lewis-cnc-floor-type-hbm/
When I would use the PDF or Word export option those fields used to show up on the print document. Now they do not display. Only text that is entered into the text editor displays, but no custom fields. I am using WordPress 4.4.1 and Woocommerce 2.5.1. I have tried using older versions of woocommerce with the same problem.
I do have Product Description ticked in the plugin settings.
Any help would be greatly appreciated.
Tia
Hi tiabradford,
PODS stores custom fields with its own logic and keys. WooPP plugin can't detect those. I'll add it in our to-do list and make it available in future releases.
(@tiabradford)
Thank you.
Tia
(@bjorn)
Do you have any advice on how to call the custom field values by editing the plugin template?
In woocommerce-pdf-print/functions.php file on line 369 you can add new custom filed title and values in these two arrays:
$custom_tab_title_html
$custom_tab_content_html
Woocommerce PDF Print Custom Field
To get current product custom fields you can use:
$product_meta = get_post_meta( $post->ID )
