Problems with badges
11.4 K Views
(@kwisoo)
[#3829]
I've set up myCRED badge image, but I can't see it properly.
It's the same for all sizes.
Do you have any code to modify it as in the description?
Here is my problem. I hope you can fix this problem as soon as possible.
Thanks.
wpdiscuz
(@kwisoo)
Hi @kwisoo,
The image SRC is not correct. Please, try to change the image and check again.
SRC
(@kwisoo)
I checked in exactly the same way as you.
I've changed images several times and I've changed caching, but I still don't get images.
The image is displayed correctly in the badge menu.
The user profile that obtained the badge also shows the correct image.
Only wpdiscuz is not properly displayed.
Can you help me with what's the problem?
wpdiscuz 2
wpdiscuz 1
Hi @kwisoo,
We don't find such an issue on our test websites. We'll need admin accesses to check the issue. Could you please send the admin login details to info[at]gvectors.com email address to allow us to check it?
(@kwisoo)
Thank you.
I sent you the information in the e-mail you gave me.
