WpdiscuzHelperEmail::addSubscription() Not Working With Bedrock Folder Structure (404 Error)
(@jeffrey-zienowicz)
Topic starter   [#5503]
I'll use my dev site URLs in this description, but I've confirmed that the problem occurs on a site with a "real" TLD. This project uses Bedrock, which modifies the WP folder structure. As a result, the "WordPress Address" and "Site Address" WP settings are different from a vanilla WP install:
WordPress Address: https://geoex.test/wp
Site Address: https://geoex.test
The site's blog is at https://geoex.test/blog, so there is a Custom Structure in Permalinks settings: /blog/%postname%/
The wpDiscuz subscription form submits and calls the addSubscription() method in WpdiscuzHelperEmail. At line 62, this redirect takes place:
wp_redirect(get_bloginfo('wpurl') . '/' . $httpReferer)
The problem is that the resulting URL for the redirect starts with:
https://geoex.test/wp//blog/
instead of:
https://geoex.test/blog/
This, of course, results in a 404 error.
Hi @jeffrey-zienowicz,
the issue doesn't have any relation to the wpDiscuz plugin. This may come from your website configuration. If you send the admin login details to info[at]gvectors.com email address, the developers will check the issue.
@astghik, I have sent you credentials for the project's staging site. I have a redirect in place as a  workaround: wp/blog/(.+) to blog/$1
@jeffrey-zienowicz,
The developers can't check the website by accesses you've sent,  because of the plugin editing is disabled.
Posted by: @jeffrey-zienowicz
You can continue to use this way, till we will update the version. In the new version, this issue is already fixed.
@elvina, Ah, right: DISALLOW_FILE_MODS is set to "true." I could change that for you, but it sounds like you've identified and fixed the issue for the next release, so I take it you don't actually need to do any analysis of my site?
ok, please wait for an update.
