wpDiscuz plugin activated but standard commenting system stays
(@nateno)
wpDiscuz doesn't work properly: while it is activated on my site, the default wordpress commenting systems stays!
Some themes don’t use <?php comments_template() ?> WordPress template function, thus wpDiscuz can’t be loaded. You should ask theme support to make sure they use this function in comment section.
Also please navigate to Dashboard > Comments > Forms and edit the Default Form. Then make sure this form is enabled for all post types and save it.
