wpDiscuz comment form missing - unique problem
(@nepenthe44)
Hi there, a while ago I was asked by Aghasi to post my problem here to observe it deeper. Ref.:
 https://wordpress.org/support/topic/contact-form-missing-code-is-fine-tho/#post-8281226
Still can't figure out what the problem is.
(@varos)
Estimable Member
HI nepenthe44,
Thanks for contacting. Could you please send us your website admin access using this email?
support[at]gvectors.com
We will wait for in order to check deeper.
(@nepenthe44)
I'm afraid that's not possible. I'm using unorthodox authentication solutions which would require me to move everything to a different address once you're finished. If there are no other ways that's ok. Thanks for the effort anyways.
(@varos)
Estimable Member
Ok nepenthe44,
Thanks for letting me know. Maybe you can clone your current website into another test server and let us check? Is that possible?
(@nepenthe44)
I'll see what I can do. It may take time tho. I'll let you know. Thanks!
