[Solved] Suggestion for Upvote/Downvote
(@steelbookpro)
Topic starter   [#3859]
I don't use the Upvote/Downvote on my site because the down vote is a problem. I suggest on option to have only the Up Vote. It will be very usefull.
Thanks !!
Fabien.
Hi @steelbookpro,
You can hide the Downvote option using the CSS code. Here is a CSS code you can use:
#wpcomm .wc-vote-link.wc-down {
display: none !important;
Please add it in Dashboard > Comments > Settings > Styling  > "Custom CSS code" textarea save it and  enable the voting feature. In this case, it'll show only the Upvote option.
Fabien reacted
(@steelbookpro)
It's work, thank you very much !
