Some broken elements with my theme
(@logaritym)
Hello, I am using the theme OneSocial by BuddyBoss and there are some issues with the plugin. I have attached a picture so that you can see. Would it be possible to style the comments the way they are on your website?
http://box2074.temp.domains/~puzzleq4/july-giveaway-2018/
Cheers
Screenshot (185)
(@logaritym)
Also, if I hover over the SHARE button and then remove my cursor for half a second a shadow of the four social networks appears nearby and then disappears. It is not a big issue, but it is a bit annoying. Another thing, if the cursor is in the text field and I switch tabs, then the profile pic in the text field 3 times quickly zooms in and zooms out. Once again, these are not as big deals, but it would be nice if they get fixed.
Great job with the plugin guys!
Arina
(@arina)
Support Team
Thank you logaritym,
Please register a new user and send login details to info[at]gvectors.com email address to allow us to check it and provide CSS solution.
