Social login on comment box
(@sallyoh)
Hi there, just fixed my reply button by deactivating jetpack comments. BUT now I have no social logins on my comment box. How do I get those back please?
Hi sallyoh,
The social login buttons you're talking about are Jetpack Comment Features. If you've deactivated Jetpack comments all its components are also deactivated. You can not use two different comment systems. You should choose one of them and keep it activated.
If you want to have Social Login buttons with wDiscuz you should install one of four social login plugins. Please go to Dashboard > Comments > wpDiscuz Settings > Social Login Tab and activate one of those plugins. Then find according Social Login plugin setting menu in dashboard left menus.
