sess_ creation
(@cloudduster)
Topic starter   [#3311]
First off, I’m just an ordinary WP blogger and know nothing about php.
Two days ago, my site got 503 and my host told me that I’m hitting my inodes limit. Apparently, my blog created a lot of sess_ files, thousands of them over the course of many months.
Now, when I open one of these sess_ files, I see this in the beginning of the file
wpdiscuz_users|a:3:{s:37:"0_5c08b653f0e24@example.com_Anonymous";a:8:{s:4:"user";b:0;s:16:"commentAuthorUrl";s:0:"";s:10:"authorName";s:9:"Anonymous";s:10:"profileUrl";s:0:"";s:11:"authorClass";s:13:"wc-blog-guest";s:12:"author_title";s:5:"Guest";s:12:"gravatarArgs";a:5:{s:23:"wpdiscuz_gravatar_field";s:25:"5c08b653f0e24@example.com";s:22:"wpdiscuz_gravatar_size";i:64;s:25:"wpdiscuz_gravatar_user_id";i:0;s:28:"wpdiscuz_gravatar_user_email";s:25:"5c08b653f0e24@example.com";s:21:"wpdiscuz_current_user";b:0;}s:6:"avatar";s:209:"<img src="https://www.webbline.com/wp-content/uploads/2018/11/Blank_avatar-186x186.jpeg" width="64" height="64" alt="Anonymous" class="avatar avatar-64 wp-user-avatar wp-user-avatar-64 photo avatar-default"
Every single one of them. Does this plugin creates these files? Are they suppose to stay forever or deleted after use?
Thanks.
Rina
 Rina
(@arina)
Support Team Registered
Hi @cloudduster,
Please follow these steps:
  1. Download the folder.zip
  2. Copy the file class.WpdiscuzWalker.php  file from this folder
  3. Replace the class.WpdiscuzWalker.php file in /wp-content/plugins/wpdiscuz/templates/comment folder with a file from folder.zip.
wpDiscuz uses these PHP sessions in a case to ensure high speed. This is just a temporary solution. In the next version release, we'll make this optional, so that you'll be able to choose either use the PHP sessions or not.
(@cloudduster)
File uploaded.
Thanks for your help.
