[Solved] Recent comment authors picture is so huge
(@bluviaggiatore)
hello
in my web site " recent comment authors picture" is so big . How I can fix this ?
http://prntscr.com/jmtu4e
http://prntscr.com/jmtuaj
thank you
@bluviaggiatore,
Please delete all caches, then delete all caches and another time delete all caches. Then press Ctrl+F5 to load new CSS files. In mobile browsers just use private session in mobile browsers.
(@bluviaggiatore)
thank you for the answer
ı have deleted all cache and ı applied your instructions but still ı have issue
http://prntscr.com/jmunhw
(@bluviaggiatore)
now it is ok , thank you very much , website is behind on cloudflare and purged all then it is fine
thank you very much for your help
(@mygoodnesskitchen)
Hiya,
I am having the same issue and I have deleted the caches and pressed CTRL + F5 and the avatars are still huge. I deleted the plugin and re-installed it and still I am having the same issue. I am not super technical so maybe I am doing something wrong. It looks terrible! Any suggestions, please.
Screen Shot 2018 06 02 at 9.11.06 am
