Not showing on Optimizepress Pages
 edco
(@edco)
Is there a way to make the wpDiscuz form show on Optimizepress pages?
I've made all the necessary settings as discussed here and also checked "pages" in the plugin settings, but still no form. Only the normal wordpress comment form is showing.
http://members.lovesagame.com/al100/
Thanks,
Eddie
Hi edco,
It seems you've not turned it on for Optimizepress post type, please see the screenshot:
2015-04-17_1857
 edco
(@edco)
Thank you for your answer, but as written before "page" was checked (in the settings of the screenshot). And there are only 3 post types, same as in your screenshot.
 edco
(@edco)
It does seem to work on blogposts though... just not on pages.
Hi edco,
We have no clue what's going on on your website. We need admin access to be able check and fix this issue. Could you please send admin login details to support[at]gvectors.com email address?
 edco
(@edco)
I've reached out to the Optimizepress support regarding this problem, here's their response:
I'm afraid that plugin is known not to work with pages created with the page builder. Unfortunately we are not able to make changes to the plugin you mention as that is not something we offer through support here. We would suggest reaching out to the plugin author for assistance
Would you like to try to make this work, if so I can send you temporary admin access? I'm sure I'm not the only who uses OP and wants to use your plugin.
 edco
(@edco)
Did you had the chance to check the issue? I've sent admin details to support@gvectors.com.
Thank you so much in advance!
