Not show in template Live Composer
(@bazzarello)
I’m installing the Live Composer plugin. In it, there is the module “comments” and “form comment”. I added the two modules. For other plugins of comment the automatic replacement is ok. But for the system wpDiscuz nothing show.
Look: http://www.autocustom.com.br/novotestebeta/2016/10/07/x-treme-low/
The strange thing is that other plugins work, but are not as efficient as the wpDiscuz.
You know how I can fix?
Untitled 1
Thank you!
(@varos)
Estimable Member
Hi bazzarello,
Thanks. In order to observe it deeper, could you please send us your website admin access in order to check? If you can, please use this email: support[at]gvectors.com
(@bazzarello)
Hi VaroS
Sent! Any questions please let me know (here or by email).
Thank you.
(@bazzarello)
VaroS,
Exist the shortcode of wpDiscuz?
That would solve easily.
(@bazzarello)
I insert the shortcode wpDiscuz by using this solution:
https://wp-types.com/forums/topic/integration-of-wpdiscuz-comments-system-solution-via-shortcode-works-but/
Now it is working perfectly.
Thanks.
(@varos)
Estimable Member
Ok bazzarello,
That's nice to hear.
