Not Loading to Comment Secton After Login
(@debolster)
When I set you must be logged in to post comment, and a user click the login link...
I'm expecting two things:
1. It's either the login form pops up for the visitor to login and then continue to post the comment or
2. Once the user logs in, the page should scroll to the comment section, and not the top of the page.
E.g. If the page is https://mysite.com/how-to-use-wpdiscuz
Once the user logs in, the page should scroll to https://mysite.com/how-to-use-wpdiscuz/#comments
Thanks.
Hi @debolster,
Are you using some popup login plugin?
(@debolster)
Not really.
There's a plugin comment that does what I'm talking about. Once you want to login, it pops up the login form and allows you to continue right there on the comment section without reloading the post and sending you back to the top of the page.
Note: I'm not asking that this plugin be made like that.
Number 2 is more important to me: when the user logs in, the page should load and scroll to the comment section.
Thanks.
Hi debolster,
I'm sorry, but wpDiscuz doesn't have any login functionality, you need to use some additional popup login plugin for this purpose.
This doesn't depend on wpDiscuz as well. It should be controlled by the login plugin's side.
