Login for comments
(@footbik)
Hi
when should I login for comment
when the plugin is not activated - I see a login form of the theme
when the plugin is activated I see the standard form of the wordpress
https://www.footbik.by/2016/04/27/login-for-comments/
how can this be changed?
(@footbik)
I set up a redirect to the forum. The registration page leads to an ultimate member register, the pasword-reset work too. But the login does not work and leads to the forum login
Hi @footbik,
wpDiscuz uses Wordpress native (core) login functions. May be you have some plugin, that has effects on this redirection. Please deactivate plugins one by one and check after each deactivation.
