[Solved] How to hide the comments link icon?
(@skenecat)
I have wpDiscuz set up on a members only website, so I don't want to show the url link icon next to comments. Is there a way to hide or disable this?
I tried to find the plugin css, to hide it that way, but didn't see a css file. Can someone point me to where that is?
wpDiscuz 4 comes with comment form manager. Please navigate to Dashboard > Comments > Forms admin page, then edit the Default Form and disable Website field:
wpDiscuz 4 remove website field from comment form
(@skenecat)
Hi Tom,
Thanks for the quick response. I disabled the website, and also removed the Field icon, but I still see the link icon above each comment, with the comment's url.
Could you tell me how to get to the css? Then I could at least change the icon color so it won't be visible.
The instruction above was for removing Website/Link field from comment form, that's not for removing comment link. It seems I followed you incorrect.
Navigate to Comments > Settings > Show/Hide Tab and use "Hide Comment Link" option:
wpDiscuz hind comment link
(@skenecat)
Thanks, Tom. That's exactly what I needed!
