How do i get back function " Display comment form for post types "
(@kuikikoo)
Hello Team Gvectors,
Before 2 months, i installed wpdiscuz, which allow to comment on post type (shop-order). After update and i just know that the new update delete this function. May i know how do i get back this function?
You just need to read the changelog before updating wpDiscuz. wpDiscuz 4 comes with custom comment form and fields. You can find Post Type settings in each comment form settings. This setting is moved to Form options area. Now you can create custom comment form for each Post Type. Just Navigate to Comments > Forms admin page, edit the Default Comment Form and set post types.
(@kuikikoo)
Very nice. Worked. Thank you so much.
I have leave email to : info@gvectors.com, may i ask here?
Is there any support code for woodiscuz to use all of these add-on? If available, i will purchase all of add-on bellow
Is there any way mixed all css, js...  6 of plugin to be one?
Inline image 1
