customize rating system - integrate with post average rating
(@sinho0689)
Topic starter   [#3548]
Hello, I'm planning to use wpDiscuz to implement festival participation information rating function
Like Google Play, I want to be able to enter a rating only once when I enter a comment, so I want to calculate and show the average rating of the post (festival information)
wpDiscuz comment function is nice!
So, if possible, we will continue to use additional functions such as the reply function.
Q1. How do I add the star ratings of the comments to the post's default rating and then post the statistics?
https://gvectors.com/forum/how-to-and-troubleshooting/how-to-show-total-rating-from-comments-on-specific-place/#post-11062
[wpdrating] right?
Is this the correct way to solve the question?
Q2. How can I write a comment once, or enter the comment's rating once?
(Comments and ratings you enter should be edited.)
Q3. Is there an API or endpoint that can load wpDiscuz information from another server as RESTful?
Q4. Do you also develop custom? Is it possible to request an implementation like the one above?
Is the above question possible with the basic function (including addon) setting? Do I need customize?
If you can customize it, will there be some example code to refer to?
We would appreciate your reply to each question item.
Topic Tags
Hi @sinho0689,
Thank you for your interest in wpDiscuz!
[wpdrating] right?
Yes, it's a correct way!
Please read this support topic, it should be helpful:
https://wordpress.org/support/topic/one-comment-per-user-per-post-2/
I'm sorry, but not.
I'm sorry but we don't provide custom plugin development services for this moment. I think it's easier to find devs at  https://www.freelancer.com/
