comments section not showing
(@theskyking)
After install the comments section is still invisible, although the default wordpress comments section IS visible. Help?
http://lymebook.com/bryan/2015/04/16/comment-test/
Hi theskyking111,
Please read this support topic and make sure all are set correctly on your end.
https://www.gvectors.com/questions/wpdiscuz-comment-form-is-missing/
If all is ok with settings please go to Dashboard > Plugins and make sure you don't have some plugin related to comments, all should be deactivated except wpDiscuz.
If nothing helps, please send admin login details to support[at]gvectors.com email address.
