Comments Not Showing
(@tradingschools)
I am having a problem with the following page: https://www.tradingschools.org/reviews/warrior-trading
The comments are not appearing correctly, and the comments links are not functioning. I have created a video that describes the problem.
https://share.getcloudapp.com/2NurzdYj
I attempted to disable all other Wordpress plugins to isolate the problem, but that does appear to be working either.
Hi @tradingschools
It seems there is an issue with the active theme. Could you please switch on the WordPress default theme and check again.
(@tradingschools)
No I cannot switch to "default" wordpress theme. My website has thousands of visitors each day. You want me to trash a custom built website? CRAZY.
Can you please support your product and make an attempt to fix the issue?
@tradingschools,
Could you please send the admin login details to info[at]gvectors.com email address to allow us to
check it?
