Comment section for some posts disabled, same setting though
(@chillraffe)
Hey guys, I am not sure where this topic is to be categorized, so I apologize If I am wrong here.
Anyways, for two of my blog posts the comment sections are there while for all the rest they aren't. These two are my newest post (still before I installed the Plugin though) while the others are older ones. I have however selected "comments allowed" for every post individually and I make all my post with the same "fundamental" settings, so I have no clue what the problem could be.
Does anyone have an idea?
Hi @chillraffe,
Please check the points mentioned in this doc:
https://wpdiscuz.com/docs/wpdiscuz-documentation/getting-started/missing-comment-form/
(@chillraffe)
Thank you Astghik,
this is basically what I saw in a youtube video along which I installed the (older?) "disqus" which I then proceeded to de-install again. So all of the requirement of this article: https://wpdiscuz.com/docs/wpdiscuz-documentation/getting-started/missing-comment-form/ have been met by me, unfortunately. My blog posts all run on WpOcean theme and with Elementor, all settings are the same, but only for 2 of like 10 post does it show the comment section, that is why I find it so weird and insoluble.
I just tried, If I publish a new post the comment section shows. Settings exactly the same as an older one where it does not show. Maybe I just leave it like that or post my older posts anew ... I have no clue.
Thanks anyways:)
@chillraffe,
Please let us know if you disable the wpDiscuz plugin, does the default comment form appear on the posts or not?
(@chillraffe)
It appears for the same two posts for which the wpDiscuz plugin appears when turned on. For the others however not, just like wp Discuz plugin too.
@chillraffe,
Please check this article it should be helpful:
https://elementor.com/blog/single-post-widgets/
