[Solved] Comment form not viewable by guests (non logged-in)
 P H
(@pejman-habibi)
Here is the problem:
1. I cloned the default comment form and created a "guest comment form".
2. I unticked all the items in Disable commenting for roles, changed Allow guests to comment to Yes, and entered a post ID in Display comment form for post IDs.
3. The comment form is only viewable to logged-in users on that post.
What have I missed?
Have a good day!
P H
@pejman-habibi,
Please provide a screenshot to allow us to check it.
 P H
(@pejman-habibi)
Here are some screenshots:
@pejman-habibi,
Please check the points mentioned in this support topic, for that post and leave some feedback for each one: https://wpdiscuz.com/docs/wpdiscuz-documentation/getting-started/missing-comment-form/
 P H
(@pejman-habibi)
The WpDiscuz comment form is there and can be seen and used by logged-in users, but it is not viewable by logged-out users.
I have already sent you a user account. You can use it to try out this page:
https://www.myenglishworld.org/which-meme-do-you-like-best/
A logged-in user can see the comments form and comment. A logged out user doesn't see the comment form at all.
@pejman-habibi,
There is a following code in the "Custom CSS Code" textarea, that cause the issue.
.comments-area {
display:none;
It located in the Dashboard > Comments > Setting > Styling admin page.
You just need to remove the code and check again.
 P H
(@pejman-habibi)
Thank you very much for following this up.
I'm afraid I need that CSS code as I don't want my members' comments to be visible to non-members, except for certain pages for which I'll be using the guest comment form.
Is there a CSS difference between the default comment form and the guest comment form I could use to achieve what I want, or any other way of achieving this?
@pejman-habibi,m
For farther support could you please leave certain page IDs.
 P H
(@pejman-habibi)
The page ID is 20301, but I'll be using the "guest comment form" on several pages, so ideally I need a CSS that allows me to hide the "default comment form" from non-logged-in users but not the "guest comment form" site wide.
At the moment I am using the following CSS to hide the default comment from from non-logged-in users:
.comments-area {
display:none;
.logged-in .comments-area {
display:inline;
@pejman-habibi,
Please put the code in the active theme functions.php file
add_filter('wpdiscuz_parent_comments_clauses', function ($s) {
global $post;
if (!is_user_logged_in() && !empty($post->ID) && in_array($post->ID, array(20301,))) {
$s = " AND user_id = 0" . $s;
return $s;
add_action('pre_get_comments', function ($q) {
if (!is_user_logged_in() && (wp_doing_ajax() || in_array('wpdiscuz_sticky', $q->query_vars['type__in'])) && !empty($q->query_vars['post_id']) && in_array($q->query_vars['post_id'], array(20301,))) {
$q->query_vars['user_id'] = 0;
return $q;
You can put the post ids in the array(20301,) after comma.
The code will hide the logged-in user's comments from non-logged in users.
qwerty1 reacted
 P H
(@pejman-habibi)
Thank you for this solution.
However, this means that I'll have to modify the function.php file every time I use the guest comment form on a post or page, which is not very practical.
I have come up with another idea, though, and I would like to know if you approve of it.
I have added the following code only to the "custom css" of the default comment form, but not the guest comment form:
.comments-area {
display:none;
display:inline;
As a result, the comment form is hidden from logged-out users except for the posts with the guest comment form.
I have tested this and it seems to be working.
Do you think it is a good solution?
@pejman-habibi,
Yes you can use the solution, but we'd suggest you use the following one, i.e just use the block value instead of the inline
  display: block
 P H
(@pejman-habibi)
Thanks! I'll do it.
