[Solved] Comment author indentation is not right on mobile
(@beyondju)
I do not use Avatar and due to that, I think the comment reply indentation doesn't look right on mobile.
It is fine on desktop.
I did some css customizations but even I removed all the customizations, the result is still the same.
Any idea?
Thanks..
Indentation on mobile:
Indentation on desktop:
Hi@beyondju,
Have you deleted the caches before checking? Please test it on other mobile devices or try on incognito mode. Because mobile browsers have a hard cache.
If it's not a cache issue, just leave some example URL we'll provide some solution for you.
(@beyondju)
Hi Astghik,
Thank you.
I have tried clearing the caches and ran in incognito mode, still having the same issue.
I have messaged you the test URL.
Thanks..
